I have a project which partition wall are carried direct on slab and not on beams ,now i want to convert that partition wall load (line load) to be used as floor load (area load) on the slab. How do i do that?
Do you want to apply the partition wall load on a slab? In such case, I think applying the Partial Plate Pressure Load is the only option. If that slab is meshed, applying such load could become quite tedious. This would be much easier in the Physical Modeler, however, the structure has to be created from scratch in the Physical Modeler.
What if i dont use plate,and i would like to convert that partition load to area load so as yo use it as floor load?
In that case you need to define that area from a series of beams, which could be declared as dummy beams (material with small E value and 0 density) and apply floor load to those beams.
How do i edit material property like E value and density of materials in Staad Pro Connect Edition?
You can create a custom material by going to Materials page and clicking on Create button on the right hand side.
