Hi Bentley Team,
I am looking for ISM plugin download for my newly installed Revit 2022. I used 11.02.01.007 version of ISM, but it does not support Revit 2022.
Thanks.
I sure it will be a long time before we have 2022 compatibility, we only finished out 2021 release a few months ago.
Thanks Seth!
In a separate note, are we able to generate a Revit model from the repository data created from an analytical STAAD model?
Certainly, STAAD.pro physical or analytical modeler environments can be used. And I had some news from the product manager that the Revit 2022 turnaround should be better.
Great!
That is what I was expecting, but by some reasons all ISM related buttons (Bentley Add-in) of my Revit are off when I want to generate a new model from my repository STAAD file. Maybe it is an Autodesk question.
Any link showing the step by step procedure would be appreciated.
I doubt you will get any help from AutoDESK for that.
If the buttons are greyed out, that would not have anything to do with the specific repository, but it would indicate something is not installed, or maybe you are in some Revit command mode that is controlling menu behavior.
