I just ran a calculation and it failed stating that the allocated memory is not enough, and it is asking to add MEMORY 405, what should I do because the file has been working perfeclty until I update to latest version 22.06.00.138?
and now I am getting this:
The same file was ran on the previous version 22.04.00.40 and it works just fine, there is no need to change to MEMORY 405, do I need to install again the latest version?
Can you please share the file for investigation at our end?
First thing that happens when running is that it deletes the .rcc, so no connections. I can't upload the .rcc, please send me an email where I can send it straight to you.
WBS-210 rev N_STEEL.STD
In your model I can see you have 152 primary load cases. You have used SET NL 3000 which is not required and allocating additional memory. I would suggest using SET NL 152 for the model and run it. I tried the same and it worked for me. Can you please try at your end and let me know if this helps. I am using 22.06.00.138 version.
