STAAD RCDC keeps giving me BM - Detailing Failure no matter what parameter I adjust (beam dimension, material strengths, preferred bar spacing, etc.), I tried everything including checking Beam and Axial Force Design. Code used is ACI 318-14M. Just wondering how the software arrives at this conclusion so I can better understand it. RCDC gives little to no insight on why it gives failure reports.
Can you please upload the RCDC file here? Also, upload the analysis file (.std) if possible.
Thanks & regards,
Abhisek M
Global Technical Support
Subscribe Here
3515.STRUCTURE.STD
Can you please upload the rcdc file also?
hi! there is an error everytime i try to upload rcdc file, is their any other way to upload one?
View Help/Contens/IS 13920 & CAI 318: Beam rebar diameter as per column size
