To Whom May Concern,
I recently update to Ram SS verison 17.02.01.23 SES from 17.01.
When I review the model created under the older version Ram SS, under Ram frame the icon for joint code check is disable.
However, the joint code check report can still be print. Could you please explain why?
Thank you in advance.
In Steel Standard provisions mode (or seismic provisions)? The only thing that I think of is not having any load combinations defined (or checked).
Hello Seth,
I have take a look of the latest release noted for 17.02.
Joint code check is disable for ASD design for now.
Answer Verified By: Harry Hong
I see that this is still disabled for ASD design codes. Is that correct or am I doing something wrong?Thanks
