Dear Members,
Can we check the total upcoming load on a particular member ( Beam / Column ) for which it is designed in staad pro ?
As, I am doing some check, whether load transfer on a particular beam member due to floor load is distributed properly or not.
Ex - Two way slab span 6m x 4m
load distribution on a span of 4 m beam ( triangular load distribution) - wlx/3
w - 4 kn/m2 applied by floor loading
total load on a beam including self weight and due to triangular distribution is - 0.23 x0.23x25 + (4x4)/3 = 6.59KN/m
Therefore, I am assuming 6.59Kn/m load should be distributed per meter length of the beam and the beam should be design for this particular load. Please help me to know whether this approach is correct or not ?
Also, PFA stadd model below. (Check beam 49)
)24173.Structure1.std
@Seth Guthrie
Modestas Pls help me to get the answer?
I am not sure if I understand your question. You can see what loads are applied on the members by using the PERFORM ANALYSIS PRINT LOAD DATA. This information will be reported in the Output file. However, this information is reported for each Load Case separately.
Once the design is performed, you can see the critical forces (Axial, Shear or Banding Moments) which were used for the design in the design results.
