hello guys! I have a problem with rafter to rater apex connection. I am realy confused why is it in RAM if we cant use it(if posts that I read are true)?
How can I use it?
I would like something like this:
It does per AISC code. Probably an issue with either international codes or international beam sizes not being covered yet.
I am using AISC LRFD code and taperd beam, I als tried to use on that portion regular beam but it doesent work. Could you send me your code design so I can compare?
