How can you add additional members to an existing group without the group being wiped out? Is there a better way to "group" members?
For example - say you have a truss, you might want "top chord", "bottom chords", "webs". Would you use groups for this so you could easily select and change size or property?
Thanks!
To add to this - is there a key board shortcut to "select similar" or "select group", similar to Ctrl+D in RAM Elements?
You can use "CTRL"+G to invoke group option. There you can create any group or can see any existing group. If you want to add some new members to an existing group, then after invoking group option with "Ctrl"+G, select the group. Then highlight the existing member. Now pressing ctrl select the new members. Now associate them in the existing list.
Or if you know the member numbers, you can use associate the list option or use editor file.
Answer Verified By: RFreund
