I've come across this particular issue a number of times but have never had RAM specify this much shear reinforcement before - see snapshots below. This is a one-way slab and band beam system so wouldn't be expecting shear ties in the beam like this. CS torsion design is set to wood-armer and CS design system is one-way slab. Any advice on this would be greatly appreciated and let me know if you need more information.
The following wiki explain a lot about one-way shear and torsion design in Ram Concept. If you don't find what you are looking for, then send over the file.
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/3094/ram-concept-shear-reinforcement-faq
https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/26611/ram-concept-torsion-design-tn
