RAM Structural system to RAM Concept import
I have a Concrete slab supported by a grid of Concrete Beams, Columns and perimeter walls. I have run the design for beams and columns in ram concrete. If I import only the slab to RAM Concept, along with Columns and perimeter walls, omitting the beams, will the imported slab be supported along the existing beam lines? Or should I support it using Line spring / line support?
Thank You!
