Generating Seismic Loads
Hello. Why do we have to generate seismic loads first and then the other loads after seismic loads? How can I find the seismic weight of the structure so that I can generate the seismic loads similar to floor loads instead of copying my DL and LL under seismic definitions as per IS 13920:2016. I have seen a lot of youtube videos where LL and DL are defined initially and then seismic defitions are created. After that the DL and LL are copy pasted under seismic definition using Staad Editor. It would be of great help if somebody can explain the logic behind this. Thanks in advance.
Parents Reply Children
