Hi all,
I am performing a time history analysis on a mat foundation and wondering whether there is an EASY and FASTER way to save the results from some nodes in my model.
I am using Staad.pro release 22.06.00.138
I found some old post referring to use the OpenSTAAD but after looking at the available commands. I looks like only the Displacement commands is available.
Any idea on who I can get the velocity and acceleration ?
there is a manual (VERY TIME CONSUMING) way which is selecting either the Displacement, velocity or acceleration LAYOUT and Right Click at the graph and select SAVE TXT DATA... If I go this route, it would take me days to save and later compile the data.. basically, I would need to repeat the process 864 times, just to get the results... 9nodes x 4rotating speed x 2phases x 12outputs (d(x,y,z); v(x,y,z); a(x,y,z)) = 864 file save as ...
any other suggestion?
Marcelo
Please use GetTimeHistoryResponse function for this task
