I have 2 errors but i dont know how to solve them, i have tried everything
Capstone concreto.STD
0 154.499 0.14767 571.1960258 0.6000 571.1960258 0.9500 473.1952108 0.9600 471.1700017 0.9700 469.1743131 0.9800 467.207417 0.9900 465.2686103 1.0000 463.3572143 1.0100 461.4725731 1.0200 459.6140528 1.0300 457.7810406 1.0400 455.9729437 1.0500 454.1891888 1.0600 452.4292209 1.0700 450.692503 1.0800 448.9785148 1.0900 447.2867525 1.1000 445.6167279 1.1100 443.9679679 1.1200 442.3400138 1.1300 440.7324207 1.1400 439.1447571 1.1500 437.5766044 1.1600 436.0275562 1.1700 434.4972182 1.1800 432.9852072 1.1900 431.4911512 1.2000 430.0146888 1.2100 428.5554688 1.2200 427.1131498 1.2300 425.6874 1.2400 424.2778965 1.2500 422.8843254 1.2600 421.5063813 1.2700 420.1437671 1.2800 418.7961935 1.2900 417.4633789 1.3000 416.145049 1.3100 414.840937 1.3200 413.5507826 1.3300 412.2743324 1.3400 411.0113394 1.3500 409.7615629 1.3600 408.5247683 1.3700 407.3007267 1.3800 406.0892149 1.3900 404.8900153 1.4000 403.7029155 1.4100 402.5277083 1.4200 401.3641914 1.4300 400.2121676 1.4400 399.071444 1.4500 397.9418325 1.4600 396.8231493 1.4700 395.715215 1.4800 394.6178541 1.4900 393.5308954 1.5000 392.4541714 1.5100 391.3875184 1.5200 390.3307765 1.5300 389.2837894 1.5400 388.246404 1.5500 387.2184709 1.5600 386.1998437 1.5700 385.1903794 1.5800 384.189938 1.5900 383.1983824 1.6000 382.2155786 1.6100 381.2413953 1.6200 380.2757042 1.6300 379.3183794 1.6400 378.3692979 1.6500 377.4283389 1.6600 376.4953844 1.6700 375.5703187 1.6800 374.6530284 1.6900 373.7434025 1.7000 372.8413321 1.7100 371.9467107 1.7200 371.0594336 1.7300 370.1793985 1.7400 369.3065047 1.7500 368.440654 1.7600 367.5817495 1.7700 366.7296967 1.7800 365.8844027 1.7900 365.0457762 1.8000 364.2137279 1.8100 363.3881701 1.8200 362.5690167 1.8300 361.7561832 1.8400 360.9495867 1.8500 360.149146 1.8600 359.354781 1.8700 358.5664134 1.8800 357.7839662 1.8900 357.0073639 1.9000 356.236532 1.9100 355.4713978 1.9200 354.7118897 1.9300 353.9579372 1.9400 353.2094713 1.9500 352.466424 1.9600 351.7287288 1.9700 350.9963199 1.9800 350.2691329 1.9900 349.5471046 2.0000 348.8301727
I have notices 2 issues in your file.
1. For the Time load (seismic case in your file) you have not defined any seismic mass. So, the program is throwing that error.
As a solution please define some loads in 3 directions under load case 5 before ground motion data. As a reference you may refer example number 22.
2. The materials you have used is having zero density and no Poisson's ratio value. Plaese review and put some value for the program to work as intended.
Hope this helps!
