Story stiffness calculation in staad?
Hi every one i have modelled staad with same number of columns and all the column sizes are same. so as per the staad literature the stiffness of columns calculated as 12EI/L^3. My member sizes are same and the floor heights are same in staad but the story stiffness is not same. It changes from story to story pls help?
  • There was an approximate methodology available in STAAD.Pro. The program used to compute story stiffness of a story by summing up the lateral stiffness of columns. The stiffness of a column was calculated as 12EI / L3 however this method is approximate one as it fails to capture actual story stiffness including the effect of bracings. Story stiffness should be computed using a displacement based approach. The story stiffness is calculated as the inverse of inter-story drift when a unit load is applied at the particular story. So in your case variation of story stiffness might be entirely justified. One may refer the following section for example calculation:
    Home > What's New? > STAAD.Pro CONNECT Edition > CONNECT Edition Update 3 > RR 21.03.00-2 Features Affecting the Analysis and Design Engine > RR 21.03.00-3.5 Soft Story Checks per IS 1893
Reply
