Seismic Provisions Joint Code Check Output Clarification
I wanted to clarify the output for the seismic provisions joint code check in regards to continuity plate. I am unclear of what the 0.66" under "Tf Prov (in)" is indicating. Do I need a 0.66" thick continuity plate? Also, how is RAM arriving at this 0.66 number? Last question, does this output also show that doubler plates are not required?  Thanks for your help.
Parents Reply Children
