Hi! I would like to ask for some help. I am experiencing this problem where I cannot add a floor load to my work. Every command that I attempt to generate always end up with an error message. I already checked of duplicates of notes, beams and structures but none. I also checked the accuracy of the coordinates that I put but I still cant generate the dead loads that I want to add. Here is the file of my work. I will wait for any response. Thank you so much!
3225.Three-Story Residential Building.STD
I guess, the panel you highlighted is a perfect square. if you pick a panel of rectangular type you will be able to see triangular and trapezoidal distribution.
Yes i was able to see the trianglular/trapezoidal on a rectangular type of panel. I am actually referring to the ones erected on the each side. I will attach a photo here from the internet to show. I encircled it with a white pen. I am not sure what it is called but that is what my professor's sample look like and I thought I need to follow it... i am not sure though. Anyway, I would like to thank you again for still responding. Thank you so much!
From the snap it seems an additional member load has been provided on the beam as UDL. Probably, this is the load due to brick wall.
Okay okay. That helped. Thank you so much!
Hi Melody,
You cant see the load diagram (triangular/trapezoidal) coz the setting for load scale is small (3000:1), set the scale to 10:1, see below.
