The output file shows V(D+L) = 0 . As we calculate in case of Sway 1.2 DL+1.2 LL.
I am Unable to upload RCDC file
You can zip the file and upload it following instructions in the wiki below
(+) How can I upload files in the Bentley Communities forum ? - RAM | STAAD Wiki - RAM | STAAD - Bentley Communities
STAAD and RCDC.rar
There is an offset reading issue found in RCDC where in when offsets are assigned to beams in StAAD model, offsets is not getting read in RCDC. This issue is already addressed in upcoming release which will be available to users max by July 15th.
As a temporary work around we suggest you to kindly ignore the offsets that are assigned to beams in your staad model and then design in RCDC. All the beams will then pass.
Thanks.
Hello
Thanks for your support
As per your suggestion I ignored the offsets that are assigned to beams in staad model. The members are passing in RCDC. But Still in the RCDC Beam Design Report it shows zero values in case of plastic hinge shear calculations. Please check the output file for any group (especially for sway shear, V(D+L)
STAAD AND RCDC With G1 report highlighted.rar
