FLOOR LOAD NOT GENERATING CORRECTLY WITH GROUPING IN CONNECT EDITION, WHERE AS OLDER VERSION OF STAAD PRO V8I SS6 IS TAKING CORRECTLY
Whenever using Grouping for end wall columns for wind loads and applying one-way distribution the loads are taken incorrectly,
I have attached the staad model showing the problem with connect edition, also when the same model is opened through an older version of staad pro v8i, SS6 the one-way distribution is showing correctly.
For Example, beam 23 in the model should not take any load while applied with one-way distribution, however, GZ direction UDL is also applied. Please advise us on this issue.ENQ212292-AMANA-3D.STD
Parents Reply Children
