Hello,I have exported the load cases from a STAAD model to a foundation model in a previous version CE.09.03.0014, then I have an update of the software to version V9.5.0.62. With the previous version I got the following values for punching shear checking. (Shear forces per meter)
Now, with the updated version V9.5.0.62, the same model fails for punching shear and the results are expressed in shear stresses. These values seem to be incorrect.
In both cases, there is no way to see the procedure how was punching shear checks done. Find below StaadFoundation file.
.Silo_Found.sfa
We are looking into this and will get back to you soon.
Hello Kris, have you taken a look on this?
Need some time. Will get back to you.
Thank you,iam waiting.
Continuation for steel calculation by using eurocode,as you did in punching shear
Here is a sample calculation for the area of steel for flexure for a mat per the Eurocode.PDF
Thanks you,i have some few questions on my post
communities.bentley.com/.../i-need-a-help-on-mat-foundation-design-staad-foundation-advanced-update
