Is there a way to customize this connection in RAM so the braces and beam all bolt to a common plate?
See the attached image. I am wondering if there is a way I can use one large plate to connect all of the braces and the beam to the column, using bolts into the large gusset that is shop welded to the column. Can I replicate this in RAM? if so, how?
Thanks in advance!
Parents Reply Children
