BEAM DESIGN IN RCDC
After perfoming analysis in Staad pro C.E, we are designing beams in RCDC,after importing the analysis file in RCDC the software will decide which beams will be secondary and which beams will be primary beams.
Before designing is it necessary to adjust the supporting conditions in continum and respecify the secondary and primary beams or the one assigned by the software itself will give the correct design?
