*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 11 EQN. NO. 1 LOADS APPLIED OR DISTRIBUTED HERE FROM ELEMENTS WILL BE IGNORED. THIS MAY BE DUE TO ALL MEMBERS AT THIS JOINT BEING RELEASED OR EFFECTIVELY RELEASED IN THIS DIRECTION. and several other warning
Good day Everyone!
I have several warnings in what I'm trying to design.
I designed this model in STAAD TRUSS since this is a truss.
Below are the details. Thanks in advance.
P R O B L E M S T A T I S T I C S
NUMBER OF JOINTS 121 NUMBER OF MEMBERS 197
NUMBER OF PLATES 0 NUMBER OF SOLIDS 0
NUMBER OF SURFACES 0 NUMBER OF SUPPORTS 22
SOLVER USED IS THE OUT-OF-CORE BASIC SOLVER
ORIGINAL/FINAL BAND-WIDTH= 102/ 18/ 45 DOF
TOTAL PRIMARY LOAD CASES = 4, TOTAL DEGREES OF FREEDOM = 297
TOTAL LOAD COMBINATION CASES = 5 SO FAR.
SIZE OF STIFFNESS MATRIX = 14 DOUBLE KILO-WORDS
STAAD TRUSS -- PAGE NO. 7
REQRD/AVAIL. DISK SPACE = 12.5/ 871950.9 MB
*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 11 EQN.NO. 1
*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 55 EQN.NO. 4
*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 88 EQN.NO. 7
*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 89 EQN.NO. 10
*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 60 EQN.NO. 13
*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 90 EQN.NO. 16
*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 61 EQN.NO. 19
*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 91 EQN.NO. 22
*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 62 EQN.NO. 25
*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 92 EQN.NO. 28
*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 63 EQN.NO. 31
*WARNING- ZERO STIFFNESS IN DIRECTION 1 AT JOINT 93 EQN.NO. 34
**WARNING - THERE WERE MORE THAN 12 DOF WITH ZERO STIFFNESS.
THE FIRST 12 ARE LISTED ABOVE.
TOTAL # TRANSLATIONAL= 84 TOTAL # ROTATIONAL= 0
***WARNING - INSTABILITY AT JOINT 121 DIRECTION = FZ
PROBABLE CAUSE SINGULAR-ADDING WEAK SPRING
K-MATRIX DIAG= 4.4049210E+02 L-MATRIX DIAG= 3.6663829E-07 EQN NO 54
***NOTE - VERY WEAK SPRING ADDED FOR STABILITY
**NOTE** STAAD DETECTS INSTABILITIES AS EXCESSIVE LOSS OF SIGNIFICANT DIGITS
DURING DECOMPOSITION. WHEN A DECOMPOSED DIAGONAL IS LESS THAN THE
BUILT-IN REDUCTION FACTOR TIMES THE ORIGINAL STIFFNESS MATRIX DIAGONAL,
STAAD PRINTS A SINGULARITY NOTICE. THE BUILT-IN REDUCTION FACTOR
IS 1.000E-09
THE ABOVE CONDITIONS COULD ALSO BE CAUSED BY VERY STIFF OR VERY WEAK
ELEMENTS AS WELL AS TRUE SINGULARITIES.
***WARNING - INSTABILITY AT JOINT 8 DIRECTION = FY
K-MATRIX DIAG= 4.0197194E+01 L-MATRIX DIAG= 7.1054274E-15 EQN NO 65
***WARNING - INSTABILITY AT JOINT 41 DIRECTION = FZ
K-MATRIX DIAG= 6.1183192E+02 L-MATRIX DIAG= 3.9748602E-07 EQN NO 72
***WARNING - INSTABILITY AT JOINT 2 DIRECTION = FX
K-MATRIX DIAG= 2.2704715E+02 L-MATRIX DIAG= -4.0103032E-11 EQN NO 73
STAAD TRUSS -- PAGE NO. 8
***WARNING - INSTABILITY AT JOINT 2 DIRECTION = FY
K-MATRIX DIAG= 1.4603033E+01 L-MATRIX DIAG= -2.4886759E-12 EQN NO 74
***WARNING - INSTABILITY AT JOINT 2 DIRECTION = FZ
K-MATRIX DIAG= 2.3650660E+02 L-MATRIX DIAG= -4.1524117E-11 EQN NO 75
***WARNING - INSTABILITY AT JOINT 4 DIRECTION = FY
K-MATRIX DIAG= 1.4743329E+01 L-MATRIX DIAG= 3.5527137E-15 EQN NO 95
***WARNING - INSTABILITY AT JOINT 4 DIRECTION = FZ
K-MATRIX DIAG= 2.3408224E+02 L-MATRIX DIAG= -2.8421709E-14 EQN NO 96
***WARNING - INSTABILITY AT JOINT 118 DIRECTION = FZ
K-MATRIX DIAG= 4.4165583E+02 L-MATRIX DIAG= 0.0000000E+00 EQN NO 114
***WARNING - INSTABILITY AT JOINT 119 DIRECTION = FZ
K-MATRIX DIAG= 4.5418037E+02 L-MATRIX DIAG= 2.3703706E-11 EQN NO 117
***WARNING - INSTABILITY AT JOINT 38 DIRECTION = FZ
K-MATRIX DIAG= 2.9622196E+02 L-MATRIX DIAG= 5.6843419E-14 EQN NO 153
***WARNING - INSTABILITY AT JOINT 124 DIRECTION = FZ
K-MATRIX DIAG= 4.5490480E+02 L-MATRIX DIAG= 8.2428642E-10 EQN NO 156
***WARNING - INSTABILITY AT JOINT 1 DIRECTION = FY
K-MATRIX DIAG= 1.4522596E+01 L-MATRIX DIAG= 1.7763568E-15 EQN NO 188
***WARNING - INSTABILITY AT JOINT 1 DIRECTION = FZ
K-MATRIX DIAG= 2.3057744E+02 L-MATRIX DIAG= 0.0000000E+00 EQN NO 189
***WARNING - INSTABILITY AT JOINT 39 DIRECTION = FZ
K-MATRIX DIAG= 6.1455070E+02 L-MATRIX DIAG= 1.9194886E-09 EQN NO 192
STAAD TRUSS -- PAGE NO. 9
***WARNING - INSTABILITY AT JOINT 6 DIRECTION = FY
K-MATRIX DIAG= 3.9099370E+01 L-MATRIX DIAG= 7.1054274E-15 EQN NO 194
***WARNING - INSTABILITY AT JOINT 3 DIRECTION = FX
K-MATRIX DIAG= 2.3288038E+02 L-MATRIX DIAG= -3.6948222E-11 EQN NO 226
***WARNING - INSTABILITY AT JOINT 3 DIRECTION = FY
K-MATRIX DIAG= 1.4667662E+01 L-MATRIX DIAG= -2.3252511E-12 EQN NO 227
***WARNING - INSTABILITY AT JOINT 3 DIRECTION = FZ
K-MATRIX DIAG= 2.3288195E+02 L-MATRIX DIAG= -3.6919801E-11 EQN NO 228
***WARNING - INSTABILITY AT JOINT 75 DIRECTION = FY
K-MATRIX DIAG= 5.6258032E+03 L-MATRIX DIAG= 1.8189894E-12 EQN NO 242
***WARNING - INSTABILITY AT JOINT 54 DIRECTION = FY
K-MATRIX DIAG= 5.5161260E+03 L-MATRIX DIAG= 4.9476512E-10 EQN NO 284
***WARNING - INSTABILITY AT JOINT 43 DIRECTION = FY
K-MATRIX DIAG= 5.5161260E+03 L-MATRIX DIAG= -6.9212547E-10 EQN NO 296
290. LOAD LIST 5 TO 8
291. FINISH
*********** END OF THE STAAD.Pro RUN ***********
Parents Reply Children
