Pryout Check Group of Anchors in Shear SS6 Vs Connect Edition
In the in-built RAM Connection tab of STAAD Pro V8i SS6 version, Pry out check for Group of Anchors in Shear considers negative values for e'N (-7.38 & -0.942) as shown in snap-1. Whereas when the same check is performed in RAM  Connection Connect Edition V13 update3, the values are positive (snap-2 below). Please let me know which is correct? This difference has a big impact on interaction of Shear & Tension check.
