One of our would-be client wants to get a L shape RCC column design computation done in RCDC as per IS:456 for checking purpose.
If some readyment compuation for any size L shape column is availablepl share it.
I just quickly created a file with very basic details and load case with a L shape column. Please see if this helps. I believe you will be able to extract drawings and reports from the attached RCDC file. please let us know if you need any more info.
https://communities.bentley.com/cfs-file/__key/communityserver-discussions-components-files/5932/Structure1_2D00_Column_2D00_1.rcdx3276.Structure1.STD
[AUTOMATED MESSAGE; if there is a link below, please follow that if you wish to respond to this Communities message.]
RE: RCDC L shape column design as per IS:456
communities.bentley.com/.../Structure1_2D00_Column_2D00_1.rcdxcommunities.bentley.com/.../3276.Structure1.STD
Did this answer your question?
Verify it as the answer or Reject it as the answer
View online
You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here.Flag this post as spam/abuse.
clsRCDCInfo:RestoreProjectSchema - ERROR: 3F000: schema "AN_Frame_Assignments" does not exist
