Steel Shed_Viscose Line 5_V11std (3).STDCan anyone,please able to pass these failed beams,if yes then,please let me know(if by adding top and bottom plate etc)
Which failed beams?
By seing the property of failed beam you can find failed beams
108. 132 TABLE TB H250X255X14X14 WP 0.255 TH 0.001 BW 0.255 BT 0.001COVER PLATE DIMENSIONS ARE NOT VALID. THE SECTION PROPERTY IS CALCULATED AS I-SECTION ONLY.
Can breaking of beam will be okay as I already tried for breaking member it has been passed...
*Loadcase: 1004
*Loadcase: 1006
Please Check Member No: 85 for Loadcase: 5
