Hi there,
I want to ask about the modelling technique for column in wall situation which example: I have 3 columns (in straight line) and a wall, I have to connect wall to 3 columns, 2 columns is 2 end-points and the last one is in middle. I have some questions:
1. Should I build columns first or wall first (both below slab)?
2. In case I have built columns first, could I make wall through the middle columns or I have to split the wall into 2 segments and connect to the middle column?
Thank you very much!
Neither the order of modeling (columns first or wall first) or the number of wall segments (1 segment through middle column or 2 segments split at middle column) will affect meshing or the analysis results in RAM Concept. Choose the option that is most convenient for you.
