Hi Bentley Team,
I am in the process of modeling a steel structure with some steel hoppers. Running Integrity Check and Analysis Model show no issue with no error in the model. But when I want to move to Analytical Modeling, the following message appears and it stops proceeding to analytical model. What is missing here? Again, there is no issue in the model; in fact I was successful to get to the analytical model once and not any more! Thanks.
can you please share the .stdp file here?
Try this:
1) Open that model in the Physical Modeler;
2) Go to File -> Options -> Analysis model and change the Mesh type to Triangular;
3) Transfer the model to the Analytical Modeler (it should work fine);
4) Now open the model in the Physical Modeler again and this time change the Mesh type back to Quadrangular;
5) Transfer the model back to the Analytical Modeler.
Thanks Modestas for the response!
I tried your steps and I got the same error. This time with different node numbers.
In that case attach that model here (.std and .stdp files).
