I have a structural foundation using structural slab and grade beams set on drilled CIP concrete piers. I've modeled the slab as a shell element and is being carried by beams. I originally built this model in RSS and have exported to RAM Elements to use the shell FEM. However, I'm having trouble understanding the RC Beam Design Output report. Searching I found this:
https://communities.bentley.com/other/old_site_member_blogs/bentley_employees/b/beth_suminski_blog/posts/did-you-know-ram-elements-for-concrete-design-amp-detailing
But my report does not look like this as add'l lines are added and it doesn't seem to make much sense to me (report w/ screenshot attached). Can someone please point me in the right direction of how to read this report correctly?
PDF
Hello Lee
Those extra lines are per the units of the header:
Thanks Enrique - I suspected as such but I'm curious why it's showing no reinforcing for all loads though?
Lee Oldfield, P.E.*
Structural Engineer
*NY
Can you provide your file? Secure File Upload
Uploading now (it's a large file - 315MB)
Got your file but seems that you are using both custom sections and materials. Please send it again but save it as a zip. Zipping a file
Also let me know what beam should I check.
