Good day, I read that the U.K would no longer be using the British standard in their country, and they would switch to the Eurocodes with U.K annex.
does this mean that Bentley would remove the British standard in subsequent updates since there is no more support for it?
As of now there is no such plans. In different software, we have both BS code and Euro Code with UK annex available. You can use any of them as per your choice. If anything is changed in future updates, you will be informed.
Answer Verified By: new struct
