I'm trying to use RAM Connection (13.02.01.25) to design base plates by Canadian Code CSA S16-14. I can assign a connection template in the "Canada" group called "BPl_CSA_Pinned" and it looks like this:
However, as soon as I edit the connection to include a diagonal brace, I get an error and the connection will not display. Alternatively, I can use the US base plate template to get the geometry I want, but then I can't switch to Canadian code. Does RAM Connection not include an option for designing a column base plate with brace for the Canadian code?
For Canadian code we do not have gusseted base plate. You can do pinned and fixed type there as of now.
