I am new to RAM Connection and wanted to do the moment connection in CHS sections in one of my project. Can I know whether the connection is available now? If so, which version should I install for the same? (Circular Hollow Section column and I section beam with weld connection)
For AISC code you can have such column-beam connections when the column is circular and beam is an I section:
Thank you for your reply. Instead of bolted, can we do the connection using Smart Direct welding (Moment connection) ?
Not at this point of time.
Okay, Thank you.
