Kindly let me know the reason why column reinforcement is missing in the table. Due to this, development length calculation was skipped in the calculation report.
SFA does not perform the development length check for column reinforcement extending into the foundation.
Answer Verified By: Alvin Macaumbang
SFA old version can perform development length check. However, if new version does not perform Ldh check then below snap should not appear in calculation report.
Agreed. We will remove it in the next version.
What is the foundation type (isolated footing, combined footing, pilecap, etc.) and the design code (ACI, Euro, etc.) for which you see that message?
Isolated footing design
ACI design code
