Please, I carried out a design for an RC beam in staad connect edition. On checking the design
output from RCDC, I discovered a particular beam span has 'area of reinforcement required: Asreq'
higher than the Asprov. In other words, the Asreq = 873mm2; while the Asprov (4Y16) = 804. But
the beam was reported as OK from the design output. Is there an explanation for this?
Though, from my manual check of the Asreq, the beam is okay; However, staad calculation report seems
not correct.
NB: I have experienced similar situation in designing slab in RCDC. The calculation report showed the slab
limiting L/d was less than the actual L/d but slab reported the slab was okay in deflection based on the calculation
report output. However, I did a manual check and also realized the slab was okay in deflection.
Please, is there an explanation for these errors in the RCDC calculation sheets?
Designing Concrete Structures with STAAD.Pro and STAAD RCDC
ONLY RECTANGLE, SQUARE AND T SECTIONS ARE DESIGNED AS BEAM.
ONLY RECTANGLE, SQUARE AND CIRCULAR SECTIONS ARE DESIGNED AS COLUMN.
Kindly share your RCDC file with us for further investigation.
