Does staad advanced concrete design consider (RCDC) consider the contributing effects
of the slab flanges in RC beam design? I examined the calculation report for some beams
and realized the beams are designed completely as rectangular beams. Even when you
specify them as flange beams, It doesn't change the design output.
Please, discuss. Thank You
RCDC can design beams with flanged action (T or L). As per design principles of flanged beam, RCDC uses this action only for mid-span bottom reinforcement.
Effective width of flange-action is calculated as per the provisions in code for simply-supported and continuous beams.
I am sharing below snip as a difference where same Beam is designed with Flanged action and without Flanged action, using Indian Code as an example.
For appropriate use of this functionality, following are important points to be noted –
Logic of working out effectiveness of flange action –
When user imports slab-data in beam design file, RCDC processes this data to collect following information –
As a result of this processing, RCDC uses following principles to determine the flange action –
Hi
This is for creation of L or T shaped column.
Kindly elaborate your query regarding this.
