What is meaning of Shear links in beam design "2L-#10(M)@75 + 2L-#10V " refer image.
Same is not reflected in detail cross section of beam.
Send FULL screenshot. I will explain.
full screen shot attached
full drawing screen shots attached
Shear due to torsion is added to the main shear.
If numbers of legs are more than two then,
Check is performed to ensure that the shear
due to torsion has been taken by the outer two legged stirrups.
