RAM Frame Single Angle AISC Code Check (Compression)
I understand that RAM automatically prevents a code check on certain shapes that are often intended on being for tension-only. https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/3058/ram-frame---tension-only-faq
However, I do not understand why the 2010 AISC code check of compression on a single angle (vertical brace) can be done, but then it is disallowed for 2016 AISC code check.
What is going on here? Thank you.
Parents Reply Children
