Dear,
I have generated load combinations using auto load combination. I forgot whether I used IBC 2012 or AISC 360-10. How can I check which did I use?
Is it written somewhere in text file, or I have to go through all combination and compare with specific design code?
No, input file does not store an information which rules were used during the automatic load combination generation. You would need to manually compare the factors used in the generated load combinations vs the factors used in the auto load combination rules.
Answer Verified By: Ivan Hadži Bošković
