Ram Elements HSS Truss - Assigning CHB Connections
I have a 37 foot long pitched howe truss modeled out of steel tubes in Ram Elements. When going to assign the CHB Connections I receive the error message that the connection could not be assigned since no valid joints were found. I can not assign connections to either the top or bottom chords. All of my connection angles are between 30 and 70 degrees and all sections are HSS so I dont think the connection geometry violates those stipulated in the troubleshooting guide for connections. Can someone perhaps explain where I am going wrong or if this is a bug?
Parents Reply Children
