7220.Structure1.std
AM a new here, please help me resolve the error message of
concrete design parameter is NOT supported with indian code. PERFORM ANALYSIS
SECTION PROPERTIES NOT ENTERED FOR MEMBER 347
SECTION PROPERTIES NOT ENTERED FOR MEMBER 354
SECTION PROPERTIES NOT ENTERED FOR MEMBER 361
SECTION PROPERTIES NOT ENTERED FOR MEMBER 379
SECTION PROPERTIES NOT ENTERED FOR MEMBER 463
Thank you Royal Civil Design Center for helping me
can you please cheak this again
8244.Structure1.std,
Thank you very much sir,
After making corrections as shown by you i got the design details.
but even now its showing some warnings like *** WARNING:LENGTH TO DEPTH RATIO FOR MEMBER 58 IS LESS THAN 2.5. WARNING:Section fails while designing section: 0.0 mm WARNING:Reinforcement % exceeds maximum limit.
