I have model a project in Staad Pro C.E, two beams are failing in shear even if i try to increase the depth of beams what maybe the problem, i need a help, level 3.325m beams
26323.Structure1.STD
Please send RCDC (RCDX) file for investigation purpose and I will revert the same
BEAM AND FOOTING RCDC.rar
What is the version of your RCDC?
Bearing capacity should be 150,concrete grade 25, reinforcement 460
Use material properties from analysis
The same you are using
May you please help me the version of RCDC which you are using
