I have model a project, when i started to design footing some of footings were not designed, what maybe the problem i need your help
0474.Structure1.STD
FAILURE DIAGNOSTICS
Project Name : 0 Client Name : 0 Engineer Name : 0 Analysis File : D:\0474.Structure1.STD Analysis Last Modified : 15-08-2021 14:12:55 No Failed Footings.
Then i don't know what is wrong iam using BS 8110,some were not designed as shown on the picture attached
