In the content portion of STAAD analysis output, for relative strength check of joints there is a message "Please refer _13920.txt file for details"
where to find this file?
The file remains in the same folder where the .std file is located.
Thanks sir.
please also guide if the 'F' and 'P' symbols signify 'Fail' and 'Pass'.
If yes, please clarify why the output file says " *** NOTE: Relative strengths of beams and columns at joints is checked against Cl 7.2 of IS-13920:2016 and no failures are detected. The relative strength checks include joints where all connected beams and columns are designed successfully."
Hello chao,
F denotes fail and P denotes Pass.
The note is misleading and we have identified that alreday. we will correct he same in future release. For the time being please refer the .txt file to know the exact situation.
