I am experiencing the error 0xc000007b. I'm trying to design Mat Foundation and when I try to press Änalyze" in the Mat foundation it appears the error shown below.
Kindly help me with this.
I also attached the file for your checking.
6332.MAT FOUNDATION 1.sfa
What is the version of the Windows operating system on your machine?
Please see the photo below.
Did you get a chance to implement the suggestion by Modestas to install 9.6.0.62? If not, could you try that?
If V9.6 too fails to start up, one of our technical support engineers would have to speak to you. If you can post a service ticket, one of them will get in touch with you.
Another option to try. If you are going to install SFA 9.6, do it with Administrative rights (right click on the installer and select Run As Administrator). Talk to your IT guy if you need help.
If you are not installing 9.6, then, uninstall whatever version you have, and re-install it with Administrative rights using the same method described above.
