How to get center of gravity with other loads
Dear all,
I would like to get the center of gravity of my tank.
I have already found it for my empty tank (thanks to the selfweight load). But once my tank is filled (or partially filled), this will change the position of my CoG.
How can I modelise it, because it will have an impact on my torques for my reactions at the supports.
What I did for the moment is putting a pressure on the lowest plates of my structure equal to the weight of the water.
And  after, I apply some wind loads and seismic loads so I guess it will have an impact on my results.
Thank you,
HAMELIN Dimitri
