I have a problem with STAAD Seismic Definition. Every time I try to set the seismic definition and switch tabs, the seismic definition information is gone. Can you please help? Please see the file attached for more information.
Arman.
STAAD Model Questions.STD
I was able to set the seismic definition when I tried to export it and import it to new file. Is there anyway that I can export the file with all the material, section properties, connection details, and supports?
The seismic definition was not correctly input in your model. The selfweight data should come after the seismic parameters. A modified file is attached for your reference STAAD Model Questions_rev.STD
Answer Verified By: Arman Yosal
