Staad - Save a Report / Table
In the results ribbon -> Reports -> Section Forces:
If you set your sorting options and loading options, you can save this report. Then you can later add it to your Postprocessing: Reports (the report that you print). Once you hit "OK" the report will bring up a table of your results. Can you save the settings somehow so you can bring up this table again? I'm imagining somewhere you can bring up the report (aka table) that you saved, but not necessarily in the printed report.
I suppose this isn't totally necessary because you can just to go the post processing report to view it, but I was just curious to see if you could pull up these tables again. This might be helpful when trying to find you largest shear or moment or highest stressed shell in different directions. When using the printed report, you either need to go through hundreds of pages or you need to constantly add/drop the saved reports.
Thanks!
