RAM Foundation to RAM concept for combine footing
Hello All,
I am currently looking into designing a foundation of the shear wall which is at the basement level and at the end of the wall there are two gravity columns.
My intention at the end is to pick those gravity columns in the foundation of the shear wall to have a combined footing.
I designed individual foundation for Shear wall and Gravity columns in RAM foundation, but now I want to combine them and see how things move forward from here.
The option I was able to establish was using RAM concept for designing a combined footing.
While transferring the RAM SS file to RAM concept I am having some trouble.
I first tried using RAM concept > Import from RAM SS file.
but when I am importing a file it shows only few foundations i.e. just Shear wall and not gravity column foundations.
Good thing I tried making ISM repository of RAM SS and imported into RAM concept and I was able to see all foundations, but RAM concept just allows a story to be imported.
Cant I import the entire structure using repository? if yes how? I tried importing another story after importing one, but gives some error.
The best option here would be If I can transfer the entire RAM SS model to the RAM concept.
I am wondering if I can simply replicate the entire model of RAM SS to RAM concept and then I can check the reactions at the base of it in both RAM SS and RAM concept to see they are same or No.
and then design a combined foundation.
Any other Idea to workout combined footing is really appreciated.
Thanks in Advance.
# NewtoRAMconcept
Parents Reply Children
  • Hi Seth Gutheri,
    In line with the above queries,
    I was able to transfer the RAM SS structure in RAM Concept,
    There is one more thing which I would want to ask you here,
    I have defined a Earth Pressure Load (Pressure Load) and some Wind Load (Nodal Load) in RAM SS.
    I had to make custom comb for same in RAM SS, I see the Load comb is not imported, nevertheless upon checking I can't even import the excel sheet or copy paste LCs in RAM concept.
    Is there a way to import the LCs or copy paste the same in RAM Concept?
    because I have more combinations and want to check the effects of same.
    Thanks. :)
  • If the loads are in some class that is not imported, then you might just re-create the loading manually in Concept. The other options are to change the loading in RAM SS to a type that is imported, or to use the Ram Concept API to create the load data (we don't yet have an API to set up load combinations). For more on that see Help - API Documentation.
  • So the loads are user defined and they are imported in the RAM concept, but they are not reflecting it in the RAM concept generated Load combination same as RAM SS and hence I had to go for custom load combinations.
    So I guess I have to work on the load combination outside of the RAM and import them, but looks like there is no solution for importing the load combination in RAM concept and I need to manually change the load combs?
