Linear Analysis Fails for Cantilever Beam Microstran V10 - Unknown reason
Hi All,
I was carrying out analysis on a cantilever after installing the new V10 of microstran and it kept failing linear analysis.
So I re-installed and trialled a 'dummy' member being 10m long with a UDL of -5 and a fixed support at node 1. I also used library values for the member section 610UB125 and material STEEL.
It appears as though the linear analysis does not even commence as the dialog box that appears has no text/descriptions. then shortly after it closes and I receive the 'linear analysis failed' dialog box.
Can someone please assist with this error? I've re-installed 3 times, but perhaps I've not purged my laptop of all the microstran files or something?
I've attached screenshots and the model.
Does anyone else have this issue?   Cantilever Failed.msw
