Hi Guys,My building period is greater than the Ts value and per ASCE7-16, 11.4.8 the code based response spectra has to be adjusted (penalized). RAM does not adjust the spectra? is there a way we can incorporate it. I am running preliminary analysis before we receive the Site Specific Parameters
I think you would have to use the generic response spectrum analysis type of loading with a user defined response spectrum table (.rsp file) in order to analyze such a case.
Answer Verified By: Masood Inamdar
Did, it. It worked fine.Thank you for the suggestions. Are you guys working on incorporating this in the RAM SS system to generate Code based spectra penalized per 11.4.8 asce 7-16?
Thank You
