Hello i need a help on how to get steel design report,how to choose report of a specific steel member,and required parameters to be seen in the report.
Which software and which code you are looking for?
Staad Pro C.E
Design codes BS 5950 and Eurocode
Hello Joseph,
BS8110 is a code related to concrete. So steel design report is not possible for this code.
For euro code EC3 this is possible. To do that provide design parameter and check code command along with track 2 parameter. Once the design is done, go to post processing. There click on report tab as shown below.
A new window will pop up from where we can set the required details.
First select steel design detail from output under items and take it on the right hand side as shown below.
Now click on Range and provide the member numbers if not for all you want to see results.
Now click on Steel design and customize the options from the page and click on ok to generate report.
Hope this helps.
Sorry i wanted to write BS 5950
Yes thank you
